- This topic has 91 replies, 6 voices, and was last updated 4 years ago by
Jane Loveys.
7 December 2021 at 8:24 PM #6680
Jane Loveys
Member
7 December 2021 at 8:25 PM #6681Jane Loveys
MemberNew timber clamped in place.
7 December 2021 at 8:27 PM #8104Jane Loveys
Member
7 December 2021 at 8:28 PM #8105Jane Loveys
MemberAnother view showing fit with roof cross members
7 December 2021 at 8:33 PM #6684Jane Loveys
Member
Another view showing fit with roof cross members7 December 2021 at 8:41 PM #6685Jane Loveys
MemberThis photo shows the new section tight against the aluminium body skin which will be bent back against the wood then tacked into place. All looking good so far. All that remains to do is create a new ‘A’ post, fit it into place, join it to the new roof section, and then bend back and tack the aluminium to the new wood. More photos to follow of my progress.
8 December 2021 at 6:49 AM #6686
Ben StevensKeymasterBrilliant progress Dave, as always inspiring me to get on out into the cold and crack on with mine!
8 December 2021 at 12:58 PM #8106Tim Wilson
ParticipantI’m enjoying this and marvelling, Dave. Impressive craftsmanship! Tim.
8 December 2021 at 3:01 PM #6689Ron Dowle
ParticipantDave, again like Ben I really should get out in the garage and take a look at woodwork on the K. The screws holding the lock ‘wedge’ on the body keep coming lose. Keep up with the posting, I am looking forward to trying out your P again
9 December 2021 at 9:15 PM #8113Jane Loveys
MemberGood evening all. I have repaired the bulkhead rot problem by letting in a small new piece of wood. This was important because one of the support bracket for the steering column is bolted onto this part of the bulkhead. I am posting photos. First one of the photos shows the new wood in place. Second one shows the underside of the bulkhead area and the steering column support stay bolted securely in place. All the rotten timber is now gone from the A post. I have rough cut a suitable piece of wood which I shall carve into a new A post over the next couple of weeks. I am currently shaping the timbers for the base of th A post, all of which were rotten. I will post photos as I go.
9 December 2021 at 9:19 PM #8114Jane Loveys
Member
9 December 2021 at 9:21 PM #8115Jane Loveys
Member
11 December 2021 at 11:01 AM #8117Charles Gough
ParticipantHello Dave
Lots of good work on your P. I have used glue to make sections up and then used them as a pattern to make another. I found the second one comes together quite quickly as all you are doing is copying the first, sounds easy doesn’t it. Keep up the good work your doing a grand job, by the way my M is at Pitney’s getting the body finished off, kind regards from both of us.
Charles and Fiona
7 January 2022 at 7:59 PM #8129Jane Loveys
Member<p style=”text-align: right;”>I have spent quite a bit of time in the workshop since Christmas and have now finished and screwed the bottom pieces of the ‘A’ frame in place. I have roughly cut out my main ‘A’ frame post, and started to carve it into shape. This will take at least a week or two as everything has to fit exactly to it and around it. I have put pressure on myself to get the car back on the road by entering it for the M. A. C. Classic Rally on the 24th April. Photos of progress to follow.</p>
7 January 2022 at 8:03 PM #8130Jane Loveys
.</p> -
.</p>
