Viewing 2 posts - 1 through 2 (of 2 total)
  • #9833
    Colin Warnes kindly provided a copy of an article written by Dudley Hume in 1992 suggesting an overheating solution for Flathead owners.   You can read the article here – Proposed overheating solution for Ford Flathead V8 engines, but I’m interested to hear if anyone has tried this and what the results were.
    #9834
    Posted on behalf of Tom…
    Having re read it, I think his design is wrong, because there is no atmospheric pressure tank for the blow off. Where his 13lb cap is on the Grenada tank, there should be a pipe just under the cap which leads to a catch tank, open to atmosphere. When the system heats up, the expanding water blows past the pressure cap. Then gets sucked back in when the water cools. On his design, there is nowhere for this blow-off water to go.
  • You must be logged in to create new topics.
