- This topic has 0 replies, 1 voice, and was last updated 2 weeks, 4 days ago by
4 November 2026 at 7:00 AM #13079
Ben StevensKeymasterThe article below is reproduced exactly as it appeared in an earlier Allard Owners Club magazine.
Important: this is not current technical advice and should not be treated as a recommendation from the Allard Owners Club. It reflects the views and understanding of the original author at the time it was written, and brake-fluid products, standards and manufacturer guidance may have changed since then.
We are publishing it as part of our archive because it remains an interesting snapshot of the technical discussions taking place among classic-car enthusiasts at the time. Anyone making decisions about brake fluid for their own car should check the current recommendations for their braking system, components and chosen fluid before making any changes.
BRAKE FLUIDS
Dots are different!
Information about various brake fluids
Taken from the Mini list, September 1999DOT brake fluid numbers refer to a set of minimum specifications that a brake fluid must meet. The two main specs. Are wet and dry boiling points.
DOT 5 brake fluid is always silicone based, not by definition, but simply by the fact that it’s the only base material to date that will meet the DOT 5 specs. There are good things and bad things about silicone brake fluid as with everything else in life. The good things are it won’t eat paint and it won’t absorb water. This generally means it almost never needs to be replaced. The bad things are that it’s rather viscous, tends to hold on to any air bubbles that may become entrained in it. Unless you bleed very carefully it is very hard to get a good pedal.
I did a little research on DOT 5.1. DOT 5.1 fluids are glycol based like most DOT3 4. It will absorb water but it’s not clear at what rate from the things I read. It has wet and dry boiling points (see the table below). Some companies are selling DOT 5.1 fluids labelled as Super or Supreme DOT 4. This is probably a less confusing designation than the one chosen by the U.S. Department of Transportation since DOT 5.1 fluids show more similarity to DOT 4 fluids than DOT 5.
DOT 5.1 looks like it would be a good choice for street cars. Especially if it meets or exceeds DOT 4’s hygroscopic specs. It’s main advantage is it’s high wet boiling point.
For racers, wet boiling point shouldn’t be a concern. Brake fluid should always be changed long before it can absorb enough water to lower it’s boiling point. In the US most racers use a high performance DOT 3 fluid. Some of these have dry boiling points as high as 660F. The race car brake systems are always flushed with new before each race weekend. Sometimes even more often. DOT 5.1 should be a good off the shelf choice of racing but unlike DOT 5 it still requires periodic changes. It would be a shame to lose a race because you didn’t want to spring for a quart of brake fluid.
DOT 3
Dry boiling point: 401 F
Wet boiling point: 284 FDOT 4
Dry boiling point: 446 F
Wet boiling point: 311 FDOT 5
Dry boiling point: 500 F
Wet boiling point: 356 FDOT 5.1
Dry boiling point: 518 F
Wet boiling point: 375 FLooking back
It is interesting to revisit advice like this many years later, particularly because brake fluid is one of those subjects where terminology can easily cause confusion. DOT 3, DOT 4, DOT 5 and DOT 5.1 may sound like a simple progression, but they are not simply interchangeable upgrades, and the suitability of a particular fluid depends on the braking system and the materials used within it.The article above should therefore be read as historical opinion rather than a modern guide. That does not make it any less interesting: it shows the sort of questions owners were asking at the time, and many of the same discussions still arise today.
If you have experience of running different brake fluids in an Allard, particularly over a long period or in competition, we would be interested to hear from you. Please share your experience on the club forum.
- You must be logged in to create new topics.
